Wenn man ein Eingabefeld mit "Dezimalzahl" erstellt, lässt sich die Erweiterung nicht mehr Aufrufen.
Eingabefelder: Dezimalzahl
- Behoben
AABVeV -
17. Oktober 2025 um 19:17
Was bedeutet "die Erweiterung lässt sich nicht aufrufen"? Falls ein Fehler angezeigt wird, welcher wäre das (als Text, bitte)?
Message: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated
PHP version: 8.3.26
Error Class: wcf\system\exception\ErrorException
Error Message: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated
Error Code: 0
File: /lib/system/WCF.class.php (368)
Stack Trace: [{"function":"handleError","class":"wcf\\system\\WCF","type":"::","args":[8192,"str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated","/lib\/system\/option\/FloatOptionType.class.php",29],"file":"[internal function]","line":"?"},{"file":"lib\/system\/option\/FloatOptionType.class.php","line":29,"function":"str_replace","args":[".",",",null],"class":"","type":""},{"file":"/lib\/system\/option\/OptionHandler.class.php","line":419,"function":"getFormElement","class":"wcf\\system\\option\\FloatOptionType","type":"->","args":["entries\\data\\entry\\option\\EntryOption",null]},{"file":"/lib\/system\/option\/OptionHandler.class.php","line":358,"function":"getFormElement","class":"wcf\\system\\option\\OptionHandler","type":"->","args":["float","entries\\data\\entry\\option\\EntryOption"]},{"file":"lib\/system\/option\/CustomOptionHandler.class.php","line":106,"function":"getOption","class":"wcf\\system\\option\\OptionHandler","type":"->","args":["customOption13"]},{"file":"/lib\/system\/option\/CustomOptionHandler.class.php","line":54,"function":"getOption","class":"wcf\\system\\option\\CustomOptionHandler","type":"->","args":["customOption13"]},{"file":"/verzeichnis\/lib\/page\/EntryListPage.class.php","line":214,"function":"getOptions","class":"wcf\\system\\option\\CustomOptionHandler","type":"->","args":[]},{"file":"/lib\/page\/AbstractPage.class.php","line":117,"function":"readParameters","class":"entries\\page\\EntryListPage","type":"->","args":[]},{"file":"/lib\/system\/request\/Request.class.php","line":50,"function":"__run","class":"wcf\\page\\AbstractPage","type":"->","args":[]},{"file":"/lib\/http\/middleware\/HandleValinorMappingErrors.class.php","line":35,"function":"handle","class":"wcf\\system\\request\\Request","type":"->","args":["Laminas\\Diactoros\\ServerRequest"]},{"file":"/lib\/system\/request\/RequestHandler.class.php","line":161,"function":"process","class":"wcf\\http\\Pipeline","type":"->","args":["Laminas\\Diactoros\\ServerRequest","wcf\\http\\RequestHandlerMiddleware"]},{"file":"/verzeichnis\/index.php","line":4,"function":"handle","class":"wcf\\system\\request\\RequestHandler","type":"->","args":["entries"]}] -
20. Oktober 2025 um 12:40 Hat das Label Behoben hinzugefügt.
